Graph's property in SubVi doesn't take effect on MainVI?
I have a main-vi which uses a sub-vi. The sub-vi is displaying graph. I have customized the property of the graph in SubVI, ie. the XScale and cursor position. This setting does take effect on the graph of the sub-vi. However, it doesn't take effect on the graph of main-vi.
Must I set the property of the graph from main-VI?
Is there any way to get what I want by  setting only from Sub-VI?
Thank you.
(2,664 Views)
the SubVI doesn't set the propertys for the Graph in MainVI because it doesn't know that it should do it.
To set the properties of a graph in the MainVi you can use a refernece:
Main.vi:
Sub.vi:
(2,653 Views)
Hey yoppy,
NWOmason is correct, in that the easiest way to do this is by passing a reference to the sub VI. Here is an article on how to do this if you need more information. Have a great day!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(2,628 Views)
