Graph scaling question
Using the graph palette tools on a XY graph having 2 Y scale, I would like to scale the first Y axis without changing the second one. I use LV 6.0.2. Any tips? Thanks
(2,795 Views)
If you simply right click on the scale in question, you can format that. Just be sure to uncheck the Autoscale axis on the pulldown menu.
eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,795 Views)
