Graph simplified image export....a way to export with the same background color?
Here is my graph in labview
And here is my graph when I export the simplified image
Is it possible to keep the black background after export?
(1,582 Views)
If you want the background, use the invoke node => Export Image instead.
George Zou
(1,564 Views)
It looks like zou answered your question but I just want to mention that the "simplified image" is made the way it is (white background) because this is intended for printing.
Nobody wants to empty their black ink cartridge printing a chart with solid black background.
In general charts with a black background are frowned upon when they are put into a document for this very reason.
=== Engineer Ambiguously ===
(1,533 Views)
Ahhhh ok thanks guys!
(1,524 Views)
Welllllll it still didn't seem to work. I attached my VI, but here is a screenshot. I know this isn't proper code, I should be using events but I'm just playing around right now
(1,521 Views)
Try attached VI.
George Zou
(1,510 Views)
