Graph with labels in plot area - is it possible?
Hi all!
I  am going to show some CAN frames getting from a digitizer card connected to a CAN bus circuit and i need to mark the parts of the frame like arbitration ID, the stuffed bits etc as the attached picture shows.
Do You have any idea how could i solve this?
Thx in advance!
Message 1 of 11
(4,828 Views)
Hello ghost,
I am sorry but at the moment it is not possible to mark the areas programatically. What you could do is, if the length of the waveform is constant, to load a picture as background for the graph that marks the different areas.
Best regards
Philipp N.
NIG AE
Message 2 of 11
(4,809 Views)
It's not a good news.
Thx
Message 3 of 11
(4,799 Views)
Have you looked at annotations?
Ben
Message 4 of 11
(4,794 Views)
Yes, but it marks only one point, not a range.
Message 5 of 11
(4,790 Views)
Then look into using the pciture control to render the image.
This thread has a lot of links.
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=14&jump=true
Ben
Message 6 of 11
(4,787 Views)
I came across this screen shot of an old VI that I did. Is this something like you want to do? If so, it will take me some time to come up with the code. I don't remember offhand how I did it.
Message Edited by Dennis Knutson on 12-08-2006 07:57 AM
Message 7 of 11
(4,782 Views)
It takes a while to get these old brain cells moving first thing in the morning. The graph in the screen shot is actually an xy graph on top of an intensity graph. The annotation is just a list of cursors
Message 8 of 11
(4,770 Views)
Thank You for your effort!
Best regards:
  Laszlo Gosztola
Message 9 of 11
(4,755 Views)
If you have LabVIEW 8.0 or later, you can use the "plot Images: front|middle|back" property to draw directly on the graph area using any image commands. I think it should be quite easy to implement:
Have a look at:
LabVIEW ships with two examples for this. Look for "envelope.vi" and "plot images.vi" in the example finder.
Message 10 of 11
(4,728 Views)
