Graph with two Y axes has wrong time
So I'm reading data from a sensor and then show in a graph the data. This graph has two Y axes and share the same X axe. My grpah should show the time at that moment (see img1)
img1img1
The problem I see is that the time in the graph is not the real time.
This is how I mange the graph (img2 and img3)
img2img2img3img3
What can I do to fix this error?
Message 1 of 9
(4,731 Views)
Your data doesn't have time info, so it can be in graph settings. Try it
Message 2 of 9
(4,710 Views)
Thank you for answering.
I have tried your advice but I still have the same error.
Message 3 of 9
(4,701 Views)
Can you attach vi or FP with this graph?
Message 4 of 9
(4,679 Views)
What I have is what you can see in the images I posted in the first thread and this new image:
img4img4
Message 5 of 9
(4,668 Views)
Hi yavs,
the Offset and/or the Multiplier are wrong. Or switch on Autoscale…
Message 6 of 9
(4,662 Views)
You sad, that have tried my advice, but I see another. Compare this two images:
Message 7 of 9
(4,655 Views)
Accepted by topic author yavs
Thanks to everyone for your help.
I tried with offset=0; Multiplier=1 and with/without Autoscale but it didn't work.
I thought about a different idea with the information you gave me and found a solution.
 So first of all, everything I showed in the images above are inside a timed loop that is executed every 1 second.
The next image attached is outside the timed loop.
What I did is convert time stamp at the begining of the test to DBL, then I linked this to the offset value of the graph (property node).  With this solution now each time I execute the .vi the grpah has the real time.
img5img5
Again, thank you to everyone!!
Message 8 of 9
(4,600 Views)
Hi yavs,
all this would be much easier if you would use waveforms to display them in your graph…
Message 9 of 9
(4,581 Views)
