Graph
Hi Mayur,
On my second data you can see there is Current on Y-axis and Voltage on X-axis. So want Voltage on X-axis and Current on Y-axis.
And what is the problem?
Voltage=x axis, current = y axis - just like you want it to be!
As others already said: attach your VI!
Show how it currently works and also show how you want it to work.
Tell us the exact problem you have in reaching your goal!
Message 11 of 16
(2,240 Views)
Sorry my mistake. From second data I want Voltage on Y-axis and Current on X-axis
Message 12 of 16
(2,222 Views)
You can use Swap Values to swap the X and Y data before bundling... This is btw the same as swapping the input files to begin with.
You might want to flip the axis. For that you need to get a scale reference and set the Flipped property.
Maybe, just maybe, it's a good idea to post the VI?
EDIT: OK, you finally did post the VI...
Message 13 of 16
(2,221 Views)
Accepted by topic author Mayur789
Hi Mayur,
When you want the voltage data used for Y axis you need to wire it accordingly for this BuildXYGraph expressVI!
So you aren't able to change the wiring in your VI? Or to implement a case structure with a switch? Or to use the Swap operation suggested by Wiebe on your own?
Did you take the free beginner courses offered for free by NI on their website?
Message 14 of 16
(2,215 Views)
is this what you want? i got confused.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 15 of 16
(2,203 Views)
No but thanks for the help
Message 16 of 16
(2,178 Views)
