Graph
Hello everyone, I have a little problem to make a graph. I am a beginner and would like to just draw a graph representing a bit of a word evolution scenario over time.
Let me explain, I have 2 tables:
        - 1 Table containing the states of each bit
        - 1 Table containing the duration for each bit.
Let us assume a word made up of the following way:
        0000 0000 0110 1010
      My bit array: [0; 0; 0; 0; 0; 0; 0; 0; 0; 1; 1; 0; 1; 0; 1; 0]
      My time table: [2; 10; 1; 5; 6; 1; 1; 1; 3; 8; 8; 7; 20; 1; 10; 2]
y(state of bit)
1 |     |--------------------------|    |
-------------------------------------------------------------------------------------------- x(time)
  0     2    4    6    8    10    12    14    16    18   20   22   24   26   28
Here is the beginning of what I would like to have in graph by programming.
If you have a solution for me.
Thank by advance.
David
Message 1 of 8
(3,845 Views)
I suspect you can do this with either an XY Graph or a Digital Waveform graph, but I'm not exactly clear about what you want to happen with your tables.
I guess you want 16 lines on your graph?
But I can't work out what the time table indicates from your drawings. Does each value give the duration of the current state for each bit? How should you connect the tables?
Message 2 of 8
(3,831 Views)
Hello, thanks for answer, but i don't want 16 lines, but i actually need a chronograph, with the state for each bit during the time in table.
Message 3 of 8
(3,822 Views)
Ok, so one line?
But you have a "state table" and a "duration table". I can see how you could go through the durations - e.g. with your example:
Start with some value for the first 2, then 10 later (at 12) go to the next sample, then 1 later (at 13) go to the next sample?
Is that the idea?
If so, then you want to have a shift register with the accumulated time, and then output an array of a cluster of two values, T (=sum of previous dt) and Value (index the state table).
You can put that into a graph.
Message 4 of 8
(3,817 Views)
Accepted by topic author DavidFrance44
Here's an example. Optionally use Reverse 1D Array to get the MSB/LSB switched.
Message 5 of 8
(3,810 Views)
Hello Butcher,
Thank you for answer, that's good for me, but i don't have a good graph as yours.
This is my screen, and follow a part of my programm :
What is the good graph who must take to have a good chronograph as you ?
i don't want to have any line on the graph but something as you, so only one line who show the evolution my word, bit to bit on the time.
What is the solution for this.
Thanks by advance .
Have a good day.
Message 6 of 8
(3,723 Views)
The style of the graph is set by the type, I used a Digital Waveform Graph (NXG Style), but you have I guess the Modern one.
To set the line to take all of the vertical space, right click on left axis (around Ligne 0, inside the graph (not the side bar)) and choose Autoscale Y.
To remove the sidebar/panel, right click on the graph and choose Visible Items > (uncheck) Plot Legend.
Message 7 of 8
(3,720 Views)
Thank you, and sorry for my english.
Message 8 of 8
(3,715 Views)
