Graphic Change: Methode "Picture Export"
Hey Guys,
i need some help by changing the graphic like colour & so on.
The core-aspect is that i want plot my noticed Points in my graph in a word file.
I tried it with the Methode "Picture export" and saved the frozen graph as BMP and it works but i dont like the white background.
Can someone help me by changing the graphic.
Thanks a lot
(2,361 Views)
Hello!
There is a easy way to change the graphic look by using property nodes.
-Right click at the graphic on the front panel >>create>>property node>>plot>>plot color
-The property node appears at the block diagram right click>>change all to write
-connect the property entrance with an "color box constant" (you can find it by pressing ctrl+space and typing "color box constant") to select the color
I hope it was helpful
Best Regards
Jerry
(2,335 Views)
