Graphic editor error
Well, my financial advisor tells me that it takes time... Smiley Very Happy
Message 11 of 12
(366 Views)
hex_cro ha scritto:
Thanks, but...my sequence is linear, I think a state machine is not necessary...
So I think you can easly switch from your large flat sequence to sequence of SubVI linked by error (it's not necessary to check or control the error, simply pass it through the SubVI), in this way you have a linear solution that take less space in the graph editor. You simply have to change each case with a SubVI which wraps the code of the case..
Regards.
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
Message 12 of 12
(352 Views)
