Graphical programming of Sequence profiles
When doing test stands its a very common requirement to allow the user to input a profiled pattern for a test parameter like RPM , Pressure , Flow etc. IF you the attached image you will be clear what i mean - i have shown a typical RPM profile for one cycle of test sequence. Maybe this cycle will be repeated thousands of time.  And this pattern might vary ( magnitude of  levels as well as number of points ) . So the normal method is to provide a Multi Column list box with a Column for X values and another for Y values.  While this works its not very intutive... better would be if the user can graphically create this profile data - maybe by "pulling" the profile line with cursor and positioning as required. Is there any tool for this kind of thing or anyone has attempted one such ?
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(4,311 Views)
This isn't very difficult to do, and would be an excellent "learning exercise" to teach you about cursors.  I wonder if doing a Web search for "LabVIEW Cursor" would be productive.  (Answer:  yes).
Bob Schor
(4,297 Views)
...and you'll want to provide a way for a user to fine-tune the coordinates.  I'm no gui guru, but when I did a kinda sorta similar thing, there was a distinct way to *add* a new point and a different way to *edit* an existing point.
-Kevin P
(4,286 Views)
How about making an Excel template to design the profiles then load the profile into your program?
Just save the Excel output as a .CSV file and you can read it with the "Read Delimited Spreadsheet" VI.
To me this makes more sense anyway as instead of having to create a profile every time, you can have a bunch of predefined profiles ready to load and run.
=== Engineer Ambiguously ===
(4,275 Views)
Yes ... this may be a good idea instead of messing around with cursors. Will look into this .. thanks
Raghunathan
(4,242 Views)
Bob Schor
Yes I am on it ... located a link which tells about the various ways the cursor can be implemented. But have as of now no clue how to deploy it ... will continue reading.
Raghunathan
(4,241 Views)
