Graphics with LVM file
I have a application (Wheater Station) that measures some variable and
sabes in multiples files .lvm like wind01.lvm, wind02.lvm
So, what I need is a solution to build graphics using this lvm files.
In excel I can do that, by I want a solution more "automatized", to
users do by themselves.
Can you recommend me a program that I can do this handling of
information?
Thanks.
Eduardo
(3,342 Views)
information?
LabVIEW should be able to do all you need here.
(3,336 Views)
Really???
What do I use to do that???
(3,331 Views)
Hello Du Bastos,
This is Dominic L. from Applications Engineering at National Instruments. As altenbach mentioned LabVIEW can be used to build graphics with .lvm files. What kind of graphics are you looking to build? JPEG files? Bitmap files? Graphs?
It would be much appreciated if you include more information. Without any additional information it is quite hard to help you with your application.
I look forward to hearing from you soon.
Have a nice day!
Best Regards,
Dominic L.
(3,282 Views)
