Graphing for an AI DAQmz does not function properly.
I have a VI in which I am running both AO and AI simultaneously. They are running simultaneously, the only problem is my AI graph does not show a continuous waveform, it shows spaced out dots. I thought maybe if I changed my AI to continuous rather than N samples that may solve the problem but I get an error that says I have overwritten the data. Then if I try increasing the number of samples, it still graphs the same thing. Does anyone have suggestions on how to fix this problem? I appreciate any help that you could give. I have attached my VI for reference.
Kelly
Message 1 of 20
(3,602 Views)
Are you using this for Electrophoretic Seperation. You may want to use the traditional method of reading Anolog input. Because I found that the new DAC assistant hates working with them. Anyways I hope the file I attached helps you out. Its yours but modified using older method. You could always do this the other way. If timing is and issue then add the error outs of the anolog out to the stuff I added this will make sure everything goes in order
Message 2 of 20
(3,602 Views)
Ops sent the wrong file it will take me a couple minutes to find it again sorry
Message 3 of 20
(3,602 Views)
found it I guess I didn't pay attention where I save it because I left it in the "Temporary Internet Files\Content.IE5\UQQPTPSY "
Message 4 of 20
(3,602 Views)
What did you change? I opened the file and it looks the same as my file.
Message 5 of 20
(3,602 Views)
ok I will redo what I already did see I stored the file in my temporary internet file I guess i over wrote it should finish redoing this in 1 hour sorry. I was board at work and worked on your code so give me another hour. Sorry
Message 6 of 20
(3,602 Views)
Redid the code this time I got the right file sorry about that
Message 7 of 20
(3,602 Views)
Thanks for the code. However, there is a problem. The while loop for the AI continues while the AO stops to wait for the AI to finish before continuing. Therefore, nothing shows up on any of the graphs.
Message 8 of 20
(3,602 Views)
Ya I thought that would be a problem can the card you use support Analog output waveform being sent to it. Ok I think you will find some examples if you search for it. I have a meeting now try to find example in the NI help
Message 9 of 20
(3,602 Views)
Ok I was thinking its looks like you wish always output the same wave form right what if you had and array table. For the outputs that way you could change your injection times and gate times
Message 10 of 20
(3,602 Views)
