Graphing loses Date/Time stamp.
I use Field Point to collect pressure and temperature data. The each channel is calibrated for span and offset then stored and graphed. When I combine the array of pressures and send it to a date/time graph the date ends up being a random date. I find it absurd that NI has not fixed this simple problem. I have spent months working with them and all they have done is add pages of code and 60+ shift registers to fix such a simple problem.
Is there a smart programmer out that that can do this easily. Of the 5-6 NI programmers I have worked with. None of them have been able to give me a simple fix to this problem
Thanks for any advice.
(3,011 Views)
Can you post any of the code?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,008 Views)
