Graphing problem with two plots
I know how to plot two graphs on top of one another but the problem I have
is as follows. I have the spectrum of a certain noisy signal which has been
averaged. I then change some conditions by pressing a button and the
spectrum changes to something else. of course I can capture both of these
graphically but really I want them both on the same graph - any ideas?
The data is not available at the same time - would I have to store it
somewhere in a buffer and recall it in some way? Picture a spectrum analyser
where there are two channels - you take the spectrum on channel A and then
store it. You then take the spectrum on channel B and do a comparison where
they appear together - this is my problem in essence.
thanks
tom
(3,256 Views)
You can use a shift register in while loop to act as a buffer to feedback the signal. When you press a button, keep the original data on the register and use merge signal to plot your new signal with the old signal on the same graph. Hope this help.
Bill
(3,256 Views)
If both writes to the graph occur in the same loop ( just at different iterations), use shift registers. (See attached simple LabVIEW 7.0 example).
If the writes occur in different parts of the diagram, Just write the first channel to a local variable of the graph, then later combine the two channels for the final graph.
(3,256 Views)
"Bill Choy" wrote in message
news:5065000000050000003B940100-1079395200000@exchange.ni.com...
> Bill
Thanks Bill - tried this and it failed as the array sizes were different ie
the Buffer compared with the new spectrum. They could not be bundled
together for plotting.
Tom
(3,256 Views)
Hi Tom,
Take a look of altenbach example. This is a very good one to solve your problem.
Bill
(3,256 Views)
