Graphing two analog signals vs. a third with xy plot
I am trying to plot two analog signals on the y
axis vs. an analog signal on the x axis on an xy plot. If anyone knows how to do this or has
an example vi showing it I would appreciate it.
(2,762 Views)
I think the best starting point for you is the XY graph.vi example. You will locate it in examples\general\graphs\gengraph.llb directory. The example that most probably matches your needs is '(X and Y arrays) Multi Plot' graph.
Hope it helps
Roberto
(2,762 Views)
