Grating Coupler from fiber to chip fully automatic control on Labview
wiebe@CARYA wrote:
@Blokk wrote:
Yep, based on the OP's name, he is from Germany, and the German decimal sign (,) often ruins things. Over the last years my German colleagues learned that if they want to get help from me, they should use English Windows and English LabVIEW 😄
(I know that you can change the decimal sign in the Region settings, or you program this around in LabVIEW)...
Programming LabVIEW in Europe 101:
1) Use %.; in format to string and scan from string,
2) set "use system decimals" to false.
When dealing with files, databases, etc.. When you output a string to the used, you should use what the uses choose, e.g. the system decimal point. Very confusing the first few programs you make.
There is an option in LabVIEW to globally ignore the system settings (always use "."), but really everyone should just use 1) and 2). Everyone, not just everyone in Europe.
Yes, IF you are the programmer, then you can easily avoid such issues. But there was not a single case when I got burned by an "official driver" from a manufacturer which used wrong decimal point handling, thus the driver was throwing errors under German OS...
Message 11 of 22
(1,779 Views)
All fetch commands say:
Reads the current return loss value. It does not provide its own triggering and so must be used with either continuous software triggering (see “:INITiate[n]:[CHANnel[m]]:CONTinuous?” on page 89) or a directly preceding immediate software trigger (see “:INITiate[n]:[CHANnel[m]][:IMMediate]” on page 88).
Doesn't explain reading -1.123456 iso -15.123456, but I guess that's just a testing artifact (e.g. mistake)?
Message 12 of 22
(1,776 Views)
yes it was an example but a real example. I'm actually running the VI and the value displayed on the powermeter screen is -50.6531263 dBm but the indicator shows  -5.6531263!
Message 13 of 22
(1,773 Views)
Those are often made by interns with 0 experience with LabVIEW, programming, the device, or most likely all of them.
Message 14 of 22
(1,771 Views)
What does the string indicator say?
Message 15 of 22
(1,767 Views)
I've never had a device that removed numbers from the middle of values.
Could there be some auto attenuation going on here? Maybe the display shows the absolute power, while the value you read shows the attenuated value (e.g. attenuation would be -45 dBm)?
Message 16 of 22
(1,761 Views)
No i don't think that there is attenuation mode because i'm using this device (Agilent 8163B) only to acquire power from the power sensor (ch1). Here in attachment  capture for the indicator display format
Message 17 of 22
(1,756 Views)
We need to establish if the error is between the string coming in and the integer being displayed.
So what is the string data coming in, at the time of conversion to the integer? It was on the FP of the VI you send earlier, but this screen shot doesn't show it.
Are you sure the 2nd digit is missing, or is the displayed value simply a completely different parameter?
I don't see how a missing 2nd digit would ever be useful to anyone, and I find it hard to belief you're the first to notice that.
Are you sure you need to use fetch and pow, not read\sense, mon\ret?
I'd read the manual over and over, I'm sure the answer is in there somewhere.
Message 18 of 22
(1,748 Views)
yes the 2nd digit is missing ! i'm reading the manual. The answer should be there.
Thank you very much for your interest.
Message 19 of 22
(1,743 Views)
Also read the manual from page 195, there is a simple C example code, which also shows the difference between the "Fetch" and "Read" commands. Maybe it can help you to properly implement what you want in LabVIEW...
Message 20 of 22
(1,739 Views)
