Grayed-out buttons during run-time
In Labview, is it possible to cause a Front-Panel control to be
grayed-out and disabled during run-time due to another control being
activated. My VI is used for board control/configuration, and has
several different modes of operation. If I select a certain mode, I
would like all controls not related to that mode to be grayed-out and
disabled.
Thanks in advance,
Derek.
Message 1 of 23
(19,211 Views)
Yes. Create a property node for the control and select the Disabled property. Right click the property node and select Change to Write. A zero value wired to it enables the control, 1 disables it, and 2 disables and grays it out. In some versions of LabVIEW, the property node is called an attribute.
Message 2 of 23
(19,211 Views)
Create a property node for any control you want to disable.
Right-click on control and select Create >> Property Node.
Right-click on the property node and select Change To Write.
Right-click on the property node and select Properties >> Disabled.
Wire the following constant to the property node, depending on what you want to do:
0 = Enabled
1 = Disabled
2 = Disabled and grayed out
Don't forget to enable again at some point. You may want to initialize you controls to some default enabled/disabled state when you start your program.
Message 3 of 23
(19,211 Views)
I often find that I want to do this to a bunch of front panel controls when a give process starts / stops. A nice way to group them is to create an array of references (during an initialization step for example) of all the controls to gray out, then feed that array to a subvi that performs the same operation on each reference. Please see the attached vi's and post back if you have questions.
~ Tim
Message 4 of 23
(19,211 Views)
Al S wrote in message news:<50650000000500000000C70000-1042324653000@exchange.ni.com>...
> you want to do:
> 0 = Enabled
> 1 = Disabled
Thanks, guys, for the quick replies. Much simpler to do than I thought
(slightly embarassed!), but my fro
nt-panel is much-more user friendly
now.
Message 5 of 23
(19,211 Views)
can someone convert to 6.0.2 please
Thanx, Paul.S
Message 6 of 23
(19,211 Views)
Here are the files in 6.0
Message 7 of 23
(19,211 Views)
thanx blimpieboy
Paul.S
Message 8 of 23
(19,211 Views)
How can I make controls enabled when I stop the program from front panel? They are always grayed out now.
Message 9 of 23
(18,105 Views)
         Enable all buttons outside main loop, so when you run your vi, even if your buttons were disabled, it will be enabled. other operations remains the same
Thanking you,
Sushmith
Message 10 of 23
(18,102 Views)
