I am analyzing images of hot steel slabs looking for cracks in the surface of the slab. The images are 2048 pixels wide by 14000 to 40000 pixels high. I am using NI Vision Assistant 8.5.
Sometimes the threshold does not work right when using the grayscale threshold, Local Threshold: Niblack. For smaller images it works ok, but for larger images it will not work. There are no errors, but the result is an image full of colored pixels rather than an image of particles.
I have attached some sample images. These are small crops of the larger image.
The first one is from an image about 17000 pixels high which worked properly. The second is from an image about 25000 pixels high, which did not work.
Is this strictly a size issue? Is there something I can do to fix it?
Thanks!
