Grid lines on PDA XY graph
Has anyone found a way to get grid lines onto a PDA XY graph? Is graphic overlay a possibility? Am I missing something obvious (like it can't be done)?
Chris
Practical Physics, LLC
www.practicalphysicsllc.com
(2,819 Views)
I have ran into this iussue as well, but have not been able to overcome it.  Another shortcoming is that, although I change my line style to be dashed or anything different from solid, it always comes out a solid line on the PDA.  Have you had this experience as well?
Ed DeWitt
(2,802 Views)
I haven't tried changing the line style - yet.
I did try overlaying lines from the decorations palette, but when I ran the gui, the lines got shoved to the back under the graph. Then I thought I would make the graph transparent, but when I ran it it turned black. Basically, the same results when I tried overlaying a transparent png (after installing png support of course).
Chris
(2,799 Views)
