Griffin iMic with LabVIEW 2011 OS X and MacBook Pro
I'm trying to use a Griffin iMic to do simultaineous auidio input and output on a MacBook Pro. Unfortunately, the device doesn't show up as an audio device for input or output in LabVIEW.
For example, double clicking on the Acquire Sound VI brings up the configuration dialog, but built-in input is my only choice as device 0.
The MacBook Pro only has one 1/8" jack, so I need to use a USB audio device to do simultaineous audio I/O.
This issue seems to have come up before, but the thread died with no solution.
http://forums.ni.com/t5/LabVIEW/Third-Party-Sound-Card-Audio-Interface-in-OS-X/td-p/1067668
OS X 10.6.8 and LabVIEW 2011 (11.0) student edition.
Any ideas?
-Scott
(3,461 Views)
Does it show up under "Sound" in system preferences as an input?
(3,452 Views)
Yup. The iMic works as it should for input and output. Only LabVIEW doesn't see it.
(3,448 Views)
Hello ScottH,
I see on that same thread you pointed out that R&D is still working on the CAR (Corrective Action Request) #205484 to make LabVIEW work with third party audio cards. I apologize for the inconvenience, but there doesn't appear to be a workaround for that yet.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(3,424 Views)
That old thread is over two years old. I'm assuming that LabVIEW talks to the built-in audio device on OS X through the API that it should use for the USB audio device. It should be an easy fix.
-Scott
(3,422 Views)
Any progress on this? I'd really like to be able to use this common audio input device with LabVIEW.
-Scott
@REDS wrote:
Hello ScottH,
(3,384 Views)
