02-26-2013 03:12 AM
Ahh thanks. I did not notice the default value for the offset bounds and thought it's also +-inf. 😉
Yes, now the results agree for the fit that include an offset. Curiously, if I remove the offset from the nonlinear model (only 3 parameters) and don't wire the bounds for the stock gauss fit (to fix the offset at zero), the nonlinear filt seem significantly better (residue=3493.1) than the gauss fit (residue=5820.45). Shouldn't they agree here too??
02-26-2013 03:21 AM - edited 02-26-2013 03:33 AM
@Aojha wrote:
I have attached a n image.
That seems to be a very different problem. Your ~70 bright spots seem to be 2D gaussians with two different widths and they seem to be arranged on a very regular grid.
Maybe you could do a 2d FFT to get the main spacing in each dimension, then slice the picture into regular little squares, each containing one 2D gaussian and fit each seperately for widths and intensity.
02-26-2013 03:23 AM
hi,
thank you for the suggestion. Now it is matching with the Origin's Values.
