Guidance needed
I have viewed a lot of example on how recording the pressure pressure. I m doing a microchannel research study and I need to record the data with time interval of 500ms. I trying using the "write to spreadsheet file" and connect to the DAQmx but showing me the error of overwritten. Can anyone give me a guidance? I do really hope to make it just simple and easy.
Looking Forward to Hearing from you guys.
Best Regards,
Voon Loong
(2,491 Views)
What is the "error of overwritten"? Maybe you want to set "append=true" if you don't want to overwrite old data with every write.
Please show us your code. Your question is not very clear.
(2,487 Views)
Hi WenLoong,
I guess, the read buffer is overwritten.
I guess your sampling rate is faster and the values that you are reading is slow.
Either reduce your sampling rate or read it faster. This depends on your buffer size.
Prashant
(2,482 Views)
