H.264 raw byte streams to VLC
Will this DLL allow one to replay captured packets? I need to caprure and then replay in my application.
Message 11 of 13
(878 Views)
Hi casultycare,
You mean that you capture the UDP packets and saved them as raw data? As far as I know, the DLL would recognize only existing video file format or UDP streams. I do not know about reading raw data from a UDP stream. It might work... or not.
One thing that is very likely to work is to write a LabVIEW application that would read back those UDP packets and re-stream them using UDP. The DLL would then work.
Good luck.
Marc Dubois
Message 12 of 13
(866 Views)
Hello I am also working on similar application. I am receiving continuous data packets in LabVIEW from RTSP ethernet camera encoded in H.264 format. I am receiving this in string in LabVIEW. I want to extract info & stream video on front panel. Can anyone help me about this?
Message 13 of 13
(682 Views)
