HANMATEK HM310T
Has anyone written a LabVIEW library for this power supply? It’s a just a generic Chinese power supply, but is within budget for myself building a hobbyist lab.
If not once it comes in I’ll get started on creating one and share it here in the community.
(639 Views)
I could find a User Manual on the Web that describes the Front Panel clearly, and shows a Back Panel USB port presumably to allow control via VISA commands, but apparently the "full manual" is on the CD that they ship with the Power Supply.  Maybe I didn't look hard enough ...
Bob Schor
(585 Views)
I have a Hanmatek scope.  It didn't come with any programming guide.  I was able to guess some of the commands (based on what other scopes use).
Look at SCPI commands for similar power supplies and try those.
(570 Views)
Searching “Hanmatek GitHub” in Google resulted in two good ones. I personally liked this one because they uploaded the CD contents which has a MODBUS pdf attached to it. I’ve never worked with a library like this but will attempt it.
Worst case I just make calls to these already written python libraries.
https://github.com/joeyda3rd/modbus-power-supply/tree/main/OEM-docs
(564 Views)
Accepted by topic author VInoob
I have created the LabVIEW library and published it on my GitHub. Link is below.
https://github.com/Escobar805/LabVIEW-Hanmatek-HM310T
(460 Views)
