HC SR04 compactrio?
Is it possible to use hc sr04 with cRIO? I have NI 9205, NI 9203. If so, how should I connect the sensor to the AI module? Because this sensor has 4 pin, VCC, GND, ECHO, TRIGGER.
Thanks, I appreciate your help
(3,211 Views)
What is "HC SR04"?
(3,185 Views)
Is an ultrasonic sensor. HC SR04 is the model. I want to use it to measure the distance between an object and the sensor. I'm using this model because is small and cheap
(3,176 Views)
