HC05 and makerhub
I seem to have an error while trying to upload data to Arduino using HC05. Is the problem caused by maker hub ?
(1,597 Views)
Have you configured the UART parameters on the HC-05?
You need to hook these up to a serial terminal like TerraTerm and configure them using the "AT commands".
 https://www.itead.cc/wiki/Serial_Port_Bluetooth_Module_(Master/Slave)_:_HC-05
Also have you properly paired the HC-05 and has it installed the virtual com port in Windows?
=== Engineer Ambiguously ===
(1,567 Views)
Thanks for your reply,
I was able to connect it to the computer  and showed the com port, but there’s always an error when uploading.
I’m sorry, I’m not a professional, I’m a mechatronics student, so it’s my 1st month using Labview. I’m sure I’ve about heard the UART, but I have no idea how it works, and I really have no clue what the TerraTerm-like serial terminal is!!
(1,548 Views)
As I said you probably need to connect directly to the HC-05 (NOT through bluetooth) and configure the UART on the HC-05.
The easiest way to do this is:
  1. Connect the HC-05 to your Aduino's Tx and Rx pins.
  2. Connect a jumper from the Arduino's Reset to Ground
  3. Connect the Arduino's USB cable to your computer
  4. Now you will be connected to the HC-05 through the Adrunio's USB to Serial converter. (The Atmel chip is held in reset now so it will not interfere)
  5. Use the AT commands to configure the HC-05
(1,543 Views)
