HDL in your LabVIEW VI (using the HDL node)
hey
 how can i convert a hdl code into labview vi using hdl node? i have searched net cannot find anything relevent.
Regards
(4,439 Views)
 Hi Nolsqn,
Thanks for the post and I hope your well today.
I have found some general links for you (see below). Did you have any specific questions that aren't answered by these links? I'd be happy to answer them.
HDL Interface Node FAQ
http://zone.ni.com/devzone/conceptd.nsf/webmain/52AB872736B7CF4486256E8A00758CE3
Info on what it is, how to use it, efficency...
Importing HDL Code into FPGA VIs Using the HDL Interface Node
http://zone.ni.com/devzone/conceptd.nsf/webmain/7A09D0DA91D7D70086256E400015221A
HDL node can handle 'any' code but some minor modifications to the code need to be made. For example, the parameters need to be defined, and I/O nodes cannot be directly accessed from the HDL node so changes need to be made there as well. This link guides you through.
HDL Interface Node (FPGA Module) LabVIEW 8.0
http://zone.ni.com/reference/en-XX/help/371599A-01/lvfpga/hdl_input_node/
Help File from LabVIEW.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,426 Views)
Also read this link and see if it also serves your purpose.
Using VHDL code as Component-Level IP (FPGA Module)
https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/using-vhdl-code-as-component-level-ip-...
-Jared
(4,416 Views)
 Hi Nolsqn,
I hope your well.
Did the advice from Myself and Jared help at all? I am happy to answer questions if you have any?
Hope it did help!
Kind Regards
James Hillman
(4,394 Views)
thnx for the help ...... i juss needed basic idea.
Regards
(4,328 Views)
