[HELP] Agilent 53220A Counter Timer Will Not Initialise Using NI VI's!
I am running National Instruments 2012 Development Suite.
I have hooked up an Agilent 53220A to a PXI chassis via USB and MAX can see it.
If I use the D:\Program Files (x86)\National Instruments\LabVIEW 2012\instr.lib\Agilent 532XX Series\Public\Initialize.vi library to initialise it, it takes ages before finally timing out.  I opened all the VI and issued the commands manually using the Measurement and Automation Explorer as follows:
*IDN?\n = Returned the details of the Counter Timer.
*RST\n = Returned no errors.
*ESE 60;\n = Returned no errors.
*SRE 48;\n = Returned no errors.
*CLS;\n = Returned no errors.
: SYST:ERR?\n = The subsequent read then times out!   (delete space between ":" and "S")...
If I repeat the above but skip the "*SRE 48;" command it then works.
Any ideas why my Agilent 53220A Counter Timer does not like the "*SRE 48;" command?
Thanks.
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
(3,852 Views)
Thanks.
I have confirmed this morning that I have installed the drivers and library for LabVIEW 2012 version from the NI website.
Any ideas anyone?
Thanks.
Christopher Povey
(3,826 Views)
Since you have the same problem in MAX, I don't believe it is a LabVIEW issue. I would check the manual and with Keysight about the command and whether there is a difference between usb and gpib versions of the instrument.
(3,816 Views)
According to the User Guide and Programming Reference manual the command is Service Request Enable Register. "48" is defined as the following bits:
Bit 4 - Message Available
Bit 5 - Standard Event Summary
I will try sending "*SRE 16;" and "*SRE 32;" and see which "bit" it is having an issue with...
Christopher Povey
(3,782 Views)
I have tried some experiments and it seems to be taking exception to the "*SRE 16;" command. If I change the LabVIEW code to use "*SRE 32;" instead of "*SRE 48;" then the devices initialises without error. However the Message Available state probably impacts the other functions. So not enabling this bit might not be an option!
Christopher Povey
(3,764 Views)
