HELP: CONVERSION FROM ASCII TO LABVIEW
I am degitiging 4 chanels biomedical data by POWERLAB. I can save that
file into ASCII format or POWERLAB format. Recently I am using a
software to analyzed those data that need a file like labview format or
HP Vee FORMAT. I DO NOT KNOW THE TYPE OF THOSE FILE. How do I convert
that TEXT file into LABVIEW FILE? If any body is interested to help me,
I can send sample data file.
Thanks in advance.
Shamsuzzaman
Mayo Clinic
Rochester, MN
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,143 Views)
> Thanks in advance.
> Shamsuzzaman
> Mayo Clinic
> Rochester, MN
> Before you buy.
Shamsuzzaman,
There is no standard LabVIEW format for your file. LabVIEW can read any
kind of file of known structure. Please explain more about your problem.
Basically you can read your text file into LabVIEW direct
ly. Most likely
POWERLAB stores data into tab-delimited format and you can read it
without any problems and hope there is no special format in it.
Send to me your file.
Sergey Krasnishov,
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
(3,142 Views)
