HELP! Change from Dialog Winbdow Appearance to Default!
I need you HELP!
When I had the VI finished, I changed its appearance to "Dialog" because I didn't want to show the icons bar. Now I need to open the Diagram for updating some values, but I cannot!!! How can I open the Diagram? How can I change de Window Apperarance from "Dialog" to "Default or "Custom"???
THANKS!
(2,382 Views)
Hi! I found the answer myself... Once I interrupted the execution of the VI, I could edit the properties again... Sorry, it was too simple...
(2,382 Views)
