[ HELP ] FOR statement
Hello Guys
Can you please tell me whether this Matlab code whether correct or not??
this code use to calculate all distances from A to J points on the map ( has longitude and latitude ), the starting point coordinates ( Lat and Long ) is 3.682043 and 101.523710 and the destination is 2.227804 103.35091
for p1=3.682043:-0.5:2.227804
for p2=101.523710:0.5:103.735091
a5= 2.227804;
b5=103.35091;
[dDgree] = distance(p1,p2,a5,b5); %% this function used to find a distance between two coordinates
end
end
(3,625 Views)
Hi number,
did you notice you're asking a MATLAB question in a forum dedicated to LabVIEW?
These are two completely different programming environments and I'm sure there also exists a MATLAB forum to ask such questions...
(3,622 Views)
Of course if you are actually using the optional NI Mathscript RT module (which basically has the same syntax as matlab) from within LabVIEW, you could ask in the Mathscript forum.
Also, if you are looking for a pure g implementation using LabVIEW, here is the right place to ask. But please try for yourself first. 😉
The easiest way to find out if code is "correct" (whatever that means) is to test it using a collection of some well known non-degenerate inputs where the result can be independently verified. Have you tried?
(3,616 Views)
(3,603 Views)
