HELP I'M NEW TO CODING BUT HAVE A PROJECT (BASIC)
@Thomas_robertson wrote:
Good point.   I'll bet I coded some randomize routines wrong in the past...  So round down is always the right thing to do.  NI should revamp the random number function such that you can type in a range.
That very idea was suggested on the Idea Exchange some time ago.
Random number function improvement
Message 11 of 15
(895 Views)
The OpenG Numeric library has this already.  You can add it from the VIPM.  It will be called Random Number within Range
Message 12 of 15
(883 Views)
If you multiply by 3 and round down won't you get a number 0-3?  If you then add one, you'll get 1-4.  So what do you do to avoid the (rare) situation of getting 1.0000000  out of the random number generator?
Message 13 of 15
(826 Views)
You won't.  Just read the help.
"The number generated is greater than or equal to 0, but less than 1"
0<=x<1
So when you do a multiply by 3 and round down, you get 0 to 2.
Message 14 of 15
(815 Views)
If you read what I wrote,  1.00000 is not returned by the random number generator.  Is it 0.9999999.....
Message 15 of 15
(803 Views)
