HELP IN KEITHLEY output source PROGRAM!(how to change GPIB to serial port)
As the topic suggest,can anyone help me in changing from GBIP to serial port?The file is found inside the .lib that i attached.
filename:2400 swI Linear Stair MeasV - LED.vi
thanks!
(3,153 Views)
Replace every GPIB Write with VISA Write and replace every GPIB Read with VISA Read. Then, add some code to configure the serial port at the very beginning of your program. Open the shipping driver for the HP34401 on the Instrument I/O>Instrument Drivers palette to see the correct way to configure the serial port for baud rate, parity, etc. and termination character.
(3,145 Views)
al'right,i'll try it out tommorow,since i'm not at home and need to wait for school tommorow to do.If in doubts i'll post again.Thanks for the help and hope that u can continue to guide me!i'll try my best=D
(3,137 Views)
It is a shame that you keep posting questions for people to do YOUR job for you.
Did you even try? Or are you just posting a VI up so that someone can provide you with one that works?
Does your manager or professor or whatever know that you do no work and are haivng others do it for you?
Message Edited by nyc on 07-11-2006 10:04 AM
(3,133 Views)
zzz(yawn:manmad:)!!!!!!  I did not expect people to help me COMPLETE my work;i was just seeking advice on small portion of that program.Isn't what forum is used for?For posting questions and seeking advice from professonals and those willing to help?If you're just idling around here and doing stupid things just to show that you're an active forum user,i would think that you're a pathetic fool that have no life.Please seriously re-consider your words CAREFULLY next time before you post stupid things.Thanks=D
PS:btw i did try out the program;if not how can i ask a question?You expect the question to just pop out of my brain without thinking?and thanks the person for giving me INVALUABLE advice(the person before that lame "nyc aka joker") as it did worked,and i'm still trying out the test.Thanks for it again=D
(3,104 Views)
