HELP:Import shared library
Hello:
I'm trying to import CH365DLL.DLL with the wizard in LabVIEW 8.5.
What i do is :
1.Start the wizard,select"Tools>Import>DLL"
2.Slect the CH365.DLL and CH365DLL.C file,then click "Next"
3.Don't use any includes and defines. Click "Next"
4.Then NI says :
The shared library contains 63 function(s), among which the declarations of 3 function(s) are found in the header file and these function(s) will be imported. The remaining 60 function(s) listed below cannot be imported.
There are many warnings.
How can i make it work? Is it possible?
Besides:There is the DLL and header file.
Message 1 of 1
(2,631 Views)
