HELP: NI-488.2 Runtime 16.0: Service 'NI Configuration Manager' (mxssvr) could not be stopped. Verify that you have sufficient privileges to stop system services.
I receive this message when attempting to update my visa along with some other NI device drivers.
What would anyone suggest doing? I have attempted to hit 'Retry' and nothing worked, I fear if I hit cancel it will cancel my whole download (Which I must say is at 40% after 18+ hours). Look forward to hearing what anyone has to say! NI_ERROR.PNG
(4,290 Views)
Assuming that you're able to become sufficiently elevated to stop the system service, you could stop it manually (in the services under My Computer > Manage) and try clicking Retry after?
GCentral
(4,264 Views)
Okay, i'm able to gain access to that elevation but when I view Ni Configuration Manager, it shows me that it is "Stopping" however it never stops no matter what I do.
(4,255 Views)
Accepted by topic author Knugget
I was able to figure out what was needed to be done to stop the mxssvr process so I figured I would share. Simply open task manager and type in the command
>sc queryex mxssvr
to identify the PID for the process (In this case mine was 1976)
Next,
>taskkill /PID 1976 /F
To manually kill the process and NI Device Driver download resumes in full.
(4,222 Views)
>sc queryex mxssvr
Next,
(4,222 Views)
