HELP: Reading from a parallel port: Capability Not supported error
I have read many of the comments on the developer zone addressing this issue, but I still have not been able to resolve the problem. I need to access the 5 data lines on my parallel port, to read one bit from each, they will be sent from a parallel port on another computer. I am using Windows 2000, Labview 6. When I use the In port.Vi I get an error that reads Capability not supported, VI was stopped at node 0x1D8 of subvi "In Port.vi". Does anybody have any thougts, or a vi that would work for this very simple application. I really just need five bits. Thanks!
(3,067 Views)
Hallo, April,
Du (x) meintest am 31.07.01 zum Thema HELP: Reading from a parallel port: Capability Not supported error:
Maybe you need "hwaccess.xxx" or "accesshw.xxx" from the NI server.
Windows NT and Windows 2000 don't allow direct port access without this
packet.
Viele Gruesse!
Helmut
(3,067 Views)
Hi April,
Not all parallel port are created equal. I am drawing a blank on the term (maybe EPP Enhanced Parallel Port), but you need a port that is bi-directional.
Have you tried an external zip drive or something similar on the port?
I hope this helps,
Ben
(3,067 Views)
You need a special driver for NT. Here is a link to knowledgeBase on this subject and links to the driver.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/62790c9621f599cf8625659f0068e6e9?OpenDocument
(3,067 Views)
