HELP WITH GENERATE RANDOM FLOATING NUMBER
Create a VI to generate a random floating-point number between 0 and 1 every second and repeat for a finite number of iterations specified by the user. The VI will then return the largest number generated. An indicator will be used to count the number of iterations elapsed.
Please help me to solve this. Thank you
Message 1 of 13
(5,024 Views)
Lets see what you have so far...
Where are you getting stuck?
Former Certified LabVIEW Developer (CLD)
Message 2 of 13
(5,014 Views)
Sounds like a homework problem. We're not here to do your homework, of course. But we can help you with specific problems you have with your attempt. Can you post your existing VI?
Message 3 of 13
(5,008 Views)
Hint: use a FOR loop.  Use a Shift Register to hold the largest value.  I'll let you figure out the rest.
Message 4 of 13
(4,987 Views)
Hi Atira,
you don't need a shift register as your requirement is to return the largest random number when the VI exits.
(The shift register will help you to reduce memory requirements while the VI runs, when the user chooses to run the VI for a larger number of iterations.)
With so many suggestions you should be able to solve your homework!
Message 5 of 13
(4,959 Views)
Is this correct? I think this is so simple. Can I add something else?
Message 6 of 13
(4,915 Views)
Is this correct? But I think this is so simple? I want to add something to look this not simple
Message 7 of 13
(4,910 Views)
What do you mean I don't need a shift register? So who should I use?
Message 8 of 13
(4,905 Views)
Accepted by topic author AtiraSuhaimi
You are close. Here are a few of the changes I would make.
I would use the point by point max value. That is what you said that you were looking for. You can use the built in function to increment for the iteration count.
Tim
GHSP
Message 9 of 13
(4,901 Views)
Yep, that code does what you want and it's as simple as it needs to be. You can use the Pt-by-Pt VI to remember the max value if you want, but the shift register works just fine. You could also use an array to store ALL of the values, then get the max array value. Any of those work just fine.
Simple is good!
Message 10 of 13
(4,891 Views)
