HELP does not work correctly
In the Help does not work the function " Place on block diagram" and Find on the function palette".
Does anybody know, what can I do with this?
 Ondrej
(3,548 Views)
What is your LabVIEW version? Did it work in the past and stopped working? Did it never work? Have you tried to repair your LabVIEW installation?
(3,539 Views)
Hi, it is LabView 7.1, it never works. I have installed it couple days before. I didn’t make the reinstallation, because on the second time, it didn’t offer me any repair or reinstallation, just only new installation, so I rather didn’t do it. Should I make the installation again?
(3,531 Views)
Check this:
 Why Don't the "Place on Block Diagram" and "Find on Functions Palette" Options Work in Windows XP SP2? [link removed; article no longer available]
(3,525 Views)
Thank you very much. I trayed all three possibilities (upgrade, restarting VI Servis Locater, shuting down the firewall), but it still does not work:( May be I should instal the programm again...
(3,515 Views)
