HELP getting string with garbage value
Here i have attached front and block diagrm and vi .Problem is im getting required string displayed and with that some not required string is also getting displayed.Help me with editing it.
NOTE:   if SL Number: matches then  90610003  should be obtained. But  in my code im getting
90610003
VLPN : KA-01 I-2000
Dest ID: 100
Over Speed: 15
Admin1 : 9538991097
Admin2 : 9538991096
Admin3 : 9880899964(NOT REQUIRED BOLD ONE)
Below is the text program from which i have been searching for required string
IRU details.txt
SL Number: 90610003
VLPN : KA-01 I-2000
Dest ID: 100
Over Speed: 15
Admin1 : 9538991097
Admin2 : 9538991096
Admin3 : 9880899964
kudos welcome
(3,377 Views)
Because with that function, you get everything after the matching string, which includes all the other lines.
What you could do is search the resulting string for a carriage return and return all the data before that.
(3,374 Views)
can you be more specific.Like in terms of block diagram
kudos welcome
(3,362 Views)
Accepted by topic author omprakash
Note:  It is also possible that you need to search for a \n (line feed character) or a \r\n (CRLF) but since you didn't save any real data in you VI, I can't be sure.
(3,357 Views)
Smiley Happy...thank u.
kudos welcome
(3,350 Views)
