05-19-2008 01:09 PM
@Jim_M wrote:
Perhaps the best way to help you at this point would be for you to post your code. Once we have this, we can test it in 8.5 and see if we can replicate your issue.
05-20-2008 07:32 PM
earlevel said:
"I've tried running this window from another vi (not via the About menu), and it works perfectly. So, I tried to make an About.vi that would not open at all, but would call my About dialog vi, but this didn't work either--LabVIEW seems to always open the About.vi window, no matter what I try."
What exactly did you do when you were able to get it to run perfectly? You said calling it from another VI didn't work and for me it blinks if I just run the VI even without building it into an exe. I haven't been able to try it on a OS X machine yet but I'm getting the same behaviour with LV 8.5.1 in Windows XP. Can you give me some further detail on what you did when it worked? Thanks.
05-20-2008 08:06 PM
@S_Soroosh wrote:What exactly did you do when you were able to get it to run perfectly? You said calling it from another VI didn't work and for me it blinks if I just run the VI even without building it into an exe. I haven't been able to try it on a OS X machine yet but I'm getting the same behaviour with LV 8.5.1 in Windows XP. Can you give me some further detail on what you did when it worked? Thanks.
05-21-2008 04:07 PM
Earlevel,
I can reproduce everything you have described and I've tried a number of different things to get around it and have not had any luck. I will bring this to some of our senior LabVIEW support engineers to see if we can come up with anything, it may in fact be a bug. If that is the case then I will notify R&D. In the mean time, it looks like the flicker of the about.vi always comes from the location that it was the last time the vi was save before being built into the exe. For now, you can center the about.vi and save it before building the exe. and the problem will at least be less noticable. Thanks!
05-21-2008 04:25 PM
