11-03-2005 02:19 AM
11-07-2005 05:43 AM
11-07-2005 05:54 AM
11-07-2005 09:42 AM
Hi Francois,
A simpler way for you to manage the timing of your loops would be to use the "timed loop" VI.
This can be found if you call up the functions pallette, all functions pallette, structures pallette, timed loop pallette. It's the top VI on the left of the timed loop pallette. I have attatched a screen shot of the the selected VI showing the pallette path open.
I suggest that you place the VI on your block diagram then open the context help by clicking the help menu at the top of the screen, selecting show context help, hover your mouse over the "timed loop" VI and select the "click here for ore help" within the context help window.This popup explains the functionality of the VI and has links to working examples which will help you apply the VI within your code.
I hope this helps you
Emma R
NIUK & Ireland
11-07-2005 09:46 AM
11-08-2005 05:11 AM
Hi Francois,
Can you post up your most up-to-date version of your code for me please?
As any changes you make may affect as to which solution will be most suitable for your code.
Emma R
NIUK & Ireland
11-08-2005 05:16 AM
11-08-2005 05:17 AM
11-08-2005 05:17 AM
11-08-2005 05:19 AM
Hi Francois,
Could you please post your most up-to-date version of your code?
As any changes you have made may affect what solution is most appropriate for your application.
Emma R
NIUK & Ireland
