HMC8012 error -1073807360
I have a small program now. I use a multimeter HMC8012 from Rohde&Schwarz (Germany). Now I have a problem.
I have download the LabVIEW driver from the website (https://www.rohde-schwarz.com/de/treiber/hmc8012/).
But now when I run only the VI(Initialize with Options or Initialize). There is error -1073807360. I do not know why and how can I solve the problem.
Thank you.
(3,889 Views)
Hi hyuhao,
I can imagine that in the VI the "VISA Clear”-Function is used.
Maybe this forum entry and KB can answer Your question?
Please read the content in the links and tell me how I can help you.
Is it possible for You to try out the Flush Buffer Function instead of VISA Clear and check the behaviour of Your program afterwards? Or maybe another aproach mentioned in the forum post will give you a valuable input.
Archived: How Did the Visa Clear Function Change in Visa 3.0 from Version 2.6? - National Instruments
http://digital.ni.com/public.nsf/allkb/4A8D61E759174E7F86256E20005A8ABC
VISA Clear Vs Flush Buffer for RS-232 - Discussion Forums - National Instruments
https://forums.ni.com/t5/LabVIEW/VISA-Clear-Vs-Flush-Buffer-for-RS-232/td-p/1637690
Best Regards
Richard
(3,827 Views)
Thank you.
Tomorrow I will try.
(3,820 Views)
I have the very same problem. I have read the documentation suggeste in your post but they do not exists anymore.
If I simulate the instrument with the initializate with options VI, I dont have any problem with my program, but when I use the real intrument I obtain the -1073807360 error code. Any suggestion?
Thank you very much
regards
(3,710 Views)
