HMI for siemens 840D
Has anyone ever used Labview as a HMI (machine interface)  to communicate with a siemens 840D ??
  Is this possible?
(4,103 Views)
Quick search with general siemens products. Post in bit more detail about your requirement.
(4,095 Views)
I did not find any information directly related to your device but below is some information that might help you get started.
An HMI Architecture Overview
Siemens and National Instruments Partner to Deliver Integrated Automation and Measurement Solutions
A HMI Navigation Engine for LabVIEW
Thank you,
Simran K
(4,077 Views)
Am I correct to assume that LV can be set up to use any & all of the same plug-ins used by C programming.   For example, any active X control that can be reached via C can also similarly be reached through nodes in LV,  or could be linked to a C program which is linked to the end item?
(4,073 Views)
Yes, LabVIEW can access ActiveX commands and can also interface with C code.
Take a look at Using ActiveX with LabVIEW and Calling Code Written in Text-Based Programming Languages
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(4,046 Views)
