HOW CAN I DRAW A PARABOLIC WAVEFORM???
For the formula, you could use plain g, an expression node, or even the polynomial evaluation tool.
Message 11 of 20
(3,411 Views)
I am really sorry to disturb you, but I do not know to employ that because I am just a beginner. So may I ask you to do it for me where I really need it. I will be grateful it will be abe to do that
Message 12 of 20
(3,405 Views)
Contrary to what you might think, this forums is for help with programming. It is not a homework service that provides professional turnkey solutions for free.
If you have problems with this very simple task, you should start with a few tutorials. Try to solve it! If you get stuck, show us your attempt and we will tell you what you are doing wrong.
Your problem is also very ambiguous, because there is an infinite number of different parabolas that fit the description. You need at least three points to define a unique parabola.
Message 13 of 20
(3,394 Views)
O.K. thanks for everything, I will follow you advice and get back to you if I will face a problem
Thanks again
Message 14 of 20
(3,390 Views)
I reckon, this is what you are after
Message 15 of 20
(3,362 Views)
Sorry for the dealy in reply...Thanks a lot. it is exactly what I am lookinf for, 1000 thank you.
One more thing please, I've tried to get a digital wavefrom from that analog signal..I did sth, but I am not sure whether it is the best and the right thing or not. May I ask u to confirm that for me please..
Message 16 of 20
(3,325 Views)
save it for ver. 2013 and I'll have a look
Message 17 of 20
(3,303 Views)
I really appreciate your help
Message 18 of 20
(3,297 Views)
I see that the code executes without any errors. Could you explain why do you think it is not working correctly?
Message 19 of 20
(3,265 Views)
Thanks a lot. Actually, I just want someone to confirm that for me as I have not deal with digitization in Labview. Thanks again
Message 20 of 20
(3,222 Views)
