HOW DO I CHANGE THE FONT OF "Message to Display" IN THE Prompt User for Input
HOW DO I CHANGE THE FONT OF "Message to Display" IN THE  Prompt User for Input?
Thanks for your help
XN
(2,629 Views)
Right click and select Open front panel >> Convert.
Change the vi as you need. then you can save it as a normal sub-vi.
If you have Labview 8.6, maybe (i am not sure) you can edit the express vi. Express vis are supported in 8.6
(2,625 Views)
