HOW TO ADJUST MY FRONT PANEL & ITS OBJECTS ACCORDING TO SCREEN RESOLUTION.
Hai..
I want my fp to be visible in its standard form on all screen resolutions.I've used Maintain window prop for diff screen resolutions but it didnt work.Any Solution to this problem?
(2,505 Views)
Did you also set the "Scale all objects..." setting?
For me mostly there had to be only 1 control to be scaled or changed in proportions, like a graph or listbox, the other controls (buttons, menu rings) should remain in size. This is best done by using splitters. You can lock them, stick them to one side of the window, make them invisible.
greets, Dave
Greets, Dave
(2,482 Views)
