HOW TO CREATE A MATRIX
How would create a 2 dimesional matrix in labview that is which VI should I use.
(2,931 Views)
Pardon me, but your sentence structure was hard to decipher. I think you are asking a very basic question. If you want to know how to simply create the array, you have many options. All are found in the array tools sub-pallette.
You can use the "initialize array.vi". First, put a numeric constant on your diagram. Right click the constant and select the Representation menu item. Select from one of the offered data types. Then put the "initialize array.vi" on the diagram. Wire your constant to the element terminal. Then right-click on the dimension size terminal and select add dimension. Wire a constant to each of the dimensions to determine the size of each dimension of your two dimensional matrix. The output is a two dimensional array of the size
you have specified, filled with the constant you specified at the element terminal.
You can also put a two dimensional array constant on the block diagram. Again it is accessed through the array tools sub-palette.
jc
Mac 10.4
LV7.1
CLD
(2,931 Views)
