HOW TO GET THE PEAK VALUE OF TEMPERATURE FROM GRAPH
thank you somuch sir,we did it,
and one more thing ,is there any chance of current overshoot problem arises because of NIDAQ modue,
In my project i am taking the currents directly to the NI DAQ module through transducers,I thought that there might be because of transducers ,but i tried with an inductive load currents are coming properly. is there any way to to handle it sir.Untitled.jpg
Message 11 of 21
(1,297 Views)
Message 12 of 21
(1,297 Views)
These items look weird. Do you see those also when running the system and monitoring the DAQ data using the DAQmx Test Panel instead of your LV application?
Do these spikes (including those "overshots") really occur once per 10 minutes? Is this on purpose?
Norbert
Norbert
Expert: Geometry
Message 13 of 21
(1,283 Views)
No not once per 10 min We are not understanding that when we are getting those spikes.
If we observe the pattern in that image  spikes are happening for every one hour.
My question is it possible to handle it using labview , and is it possible because of NIDAQ MODULE
Message 14 of 21
(1,281 Views)
Well, data you are displaying in your application is data which obviously comes from the DAQ device and is scaled and possibly altered by software (driver and your user application). So the Test Panel can help you in understanding if the data is already looking like this when it is read by a standardized application directly from the driver. If the data doesn't look like having those overshots, it is your application which is creating that stuff.
If the Test Panel also shows that behavior: Is it possible, that this signal is 'valid' (read: physically present)? If you *think* not: What do you read with some alternative DAQ device (e.g. oszilloscope)?
Norbert
Norbert
Expert: Geometry
Message 15 of 21
(1,270 Views)
Those spikes are not required for us,we need to remove them.
we are also dont know that why we are getting those spikes.it is happening while observing the graph in real time too...
Message 16 of 21
(1,266 Views)
What is the physical phenomena which you observe with that transducer?
It might be an indication that there is something bad going on in your setup......
Norbert
Norbert
Expert: Geometry
Message 17 of 21
(1,262 Views)
ok sir,Thank you somuch for your valuable informtion sir,
and i am sorry if any mistakes are there from my side.
i will go through those tutorials properly .
Message 18 of 21
(1,261 Views)
No ,There is no such indications in the transducers,We simply observing the graphs ,so  there is nochance of NIDAQ MODULE mistake.
Message 19 of 21
(1,255 Views)
Very highly unlikely.  Is anything happening when these spike happen?  Things like switches/relays toggling and ground bouncing can cause weird things like this.  I also recommend you get an oscilloscope and set the trigger to capture those spikes.  That will validate the DAQ.
GCentral
Message 20 of 21
(1,251 Views)
