HOW TO ROUND UP TEXT STRING?
Hello all,
 i would lik to round up a text string so that it fits in our pre decided header size. how can i do it? any one has any logic/
For Ex: Length of string deciced: 6
            String Entered by user: LABVIEWrocks
            Output string as result of rounding, LABVIEW so, rocks is removed out...
thanks,
Now on LabVIEW 10.0 on Win7
Message 1 of 8
(4,623 Views)
@LV_Enthu wrote:
Hello all,
thanks,
Same as for any programming language, really.  I think the node you're looking for is "String Subset."  🙂
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(4,617 Views)
Spend some time looking around the string palette and you'll find that the function you need is there, pretty clearly labeled: String Subset.
EDIT: By the way, you might want to check your math: LabVIEW is 7 characters, not 6.
Message 3 of 8
(4,616 Views)
I would not call that a roundup function. It sounds like that all that you need is the basic String Subset function.
p.s. Your arithmetic is wrong. If you specify a 6 with the string "LABVIEWrocks", the output string would be "LABVIE", not "LABVIEW".
Message 4 of 8
(4,613 Views)
Here is a more generic method that will let you know how many characters you can fit into an indicator. It calculates it based on the size of the indicator and the font settings. Then as suggested use string subset to truncate the string.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 8
(4,593 Views)
ALL,
THANKS FOR THE INPUTS, typo on the math..
how would i get the other way, example, if user enters LAB, i would like to append '000' at the end of string to make the size of string always equal to 6.
Message 6 of 8
(4,586 Views)
I hope we're not doing your homework for you here.  Have you looked at the string palette at all?  The functions you need are all there.
Here's one approach: check that the input string doesn't exceed the desired length.  Create a string of all 0's of the correct length.  Use "Replace Substring" to insert the input string into the string of 0's.  Creating that string of all 0's will be slightly more complicated than it should be, but a combination of string to byte array, index array, initialize array, and byte array to string will do it.
Message 7 of 8
(4,572 Views)
Accepted by topic author LV_Enthu
Hi hope this helps you
Message 8 of 8
(4,557 Views)
