HOW TO VIEW THE SOURCE CODE OF LABVIEW
Can i convert Labview VI  to the corresponding the VHDL code?
(8,564 Views)
The sourcecode of the VI is its blockdiagram. There is no way to directly convert this to any textual language.
If you use VHDL for developement in FPGA-environments, there is one maybe interesting option for you:
If you use a NI FPGA device, you can use the LabVIEW FPGA module to program the fpga. This modules creates VHDL, but it is not possible to extract this VHDL code directly....
hope this helps,
Norbert
Norbert
Expert: Geometry
(8,559 Views)
